central heating controls.... | on ElectriciansForums
Discuss central heating controls.... in the Central Heating Systems area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hello there....
Hope someone can advise me correctly here.
Have got to do the control wiring for an 's' plan.... havent done any heating systems for years.
Just wondering what regs are regarding the following....
Megaflow and programmer are going to be up on first floor, boiler is down on the ground floor in kitchen. Locating spur next to megaflow. So was wondering do I also have to put some sort of isolation in next to boiler so supply can be killed here? Just thinking about maintenance thats all...
Thank u,
Sy
Agreed - putting the spur near the boiler makes sense. Otherwise you will need to put a notice on the boiler that circuit isolation is elsewhere.
Isolate whole lot from one point for sure.
Mate of mine who is gas safe reckons best practice is to isolution through a 3A plug into socket as "DP Isolators can go wrong". I can kind of see the point but looks a bit naff and frankly if you can't trust fittings well it raises all sorts of questions really...!
How do you isolate the thermostat if the boiler is on a plugtop?
Reply to central heating controls.... in the Central Heating Systems area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
As a "temporary" measure I went down a slightly different route. Nothing off the shelf appealed. In particular I wanted something with a good WAF...
