central heating help | on ElectriciansForums
Discuss central heating help in the UK Electrical Forum area at ElectriciansForums.net
W
Welshsparky
Wired in a y plan heating system not so long back , all was well until the boiler packed in a few months back , the new boiler has terminals for the external stat inside the control panel , my stat cable goes back to the wiring centre , the stat no longer works? Help please?
What make of boiler is it? sometimes you can link out the terminals or sometimes there's a fixed link you need to remove.
I really can't think what make the boiler is , their is a link between the two stat terminals though
Take it out and it will work fine, had this same prob the other week and a friend of mine helped me out with it, is it a combi being used as a system boiler? coz I think its for when u use an internal programmer and so don't have any other control wiring
Reply to central heating help in the UK Electrical Forum area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
