Ceramic heaters | on ElectriciansForums
Discuss Ceramic heaters in the UK Electrical Forum area at ElectriciansForums.net
Need a wee bit of help here guys. I've not been on the site for yonks but that's no excuse, also I never post but just like reading the forums to see how everybody solves different problems. I'm not much of a guy to post anything on social media so forgive me for not replying to the questions that I know the answers to.
Anyway now I have a question of my own to pose concerning the heaters in my local village hall. They are ceramic heaters and and because they are not often used moisture builds up in them and sure and certain after a while when you go to switch them on at full load, because they are full of moisture then crack! either the breaker goes or in the worst case the ceramic cracks and a new heater is required.
Now I know there is such a thing as a soft start switch which would prevent the full load being whacked on at once and would gradually allow it to build up but I find them rather expensive so what I would like to know is can I fit a dimmer switch instead as long as it is able to carry the full load? I think that I can but being in street lighting for over twenty years and obviously I am up to date with the regs I wouldd just like some confirmation or advice from the experts.
Thanks for all the advice in advance and keep up the great work for us in the trade.
Running them for some time every day might be a hard sell in this day and age of saving the rain forests and expensive electricity.
How many kW are the heaters. You could use a dimmer but you're possibly getting into the realms of very large dimmers which will be expensive. Depending on the layout maybe you could could use something similar to a star/delta starter to first switch them on in groups of two in series connection so they only get half voltage, then after a few minutes it changes over so they're back to standard supply voltage. Just a thought, how easy this would be would depend on the existing switching arrangement, if they're not switched from a central location t might not be viable.
How many heating elements of xxKW are there?
There’s a way of building up the heat that we used on analytical ovens (1600°C). By connecting the elements in various series parallel networks the power is regulated during start up. But as Marvo said, if the feeds to the various elements aren’t taken to a central point it wouldn’t be viable.
The switching won’t be cheap but the system is reliable. It comes down to what the failures are costing.
Hi guys, sorry I didn't get back to you last night as I was tired and went off to bed.So today I went and had a look at this job and it is a bit more involved than the guy who asked me thinks it is. Anyway I couldn't see the wattage of the heaters as they are all high up on the walls but there are 8 of them all individually protected by a 16A mcb. The control circuit has its own mcb and the supply side is fed from 3 3-phase contactors. I think that I would have to fit a switch for each of them and it would cost too much money as the village isn't a very big one and doesn't have a lot of money and I would be doing this as a favour anyway. I think that I'll wait until the heaters are at the end of their natural and suggest either another way of supplying them or tell them to stop buying ceramic heaters as they are liable to this kind of thing.(Funnily enough I've just had to change one at work a couple of months ago which had the same problem). Thanks again guys for all your replies, I really appreciate it.
If all the heaters are individually supplied from one control panel and as long as all the neutrals are there as well then with a couple of contactors and a timer you could feasibly reconfigure them to start up in pairs supplied in series so they'd be at half voltage for a few minutes then change over to them being individually supplied after a few minutes. I'm sure this would be a lot cheaper than sourcing 16Amp dimmers and less complicated for the user as well.
Yeh I see where you are coming from Marvo, thanks a lot for that idea. I will look into it in more detail tomorrow at work. As I said I'm trying to do it for the least amount possible as it's for the village and this idea seems the most feasible. Cheers.
Reply to Ceramic heaters in the UK Electrical Forum area at ElectriciansForums.net
Yeah, left untreated you end up with a case of this...
He can apply for an E7 tariff with or without storage heaters. It depends on his electricity usage profile on whether this is a good idea or not...
