T
Teddy54
Going to a job this evening were the owner has spot lights out and has tryed changing the lamp but that hasn't worked. Two are in the middle of the room by discription, which makes me think it isn't a loose connection. They are on transformers. I havn't had much experience with spot lights that are through transformers. Are the Transformers like to be the cause of the problem? If so are they fixable or do you need to just replace them?
Any help greatly appreciated.
