Lets go easy on the newby Pete, the OP has not specified what he is an Engineer in so we shouldn't assume its Electrical.
Welcome to the forum dl144, if you are talking about fitting a CFL lamp into a standard pendant drop or similar then the wattage usually reflected on the max lamp size due to the heat generated by them and not what current it could handle, the max figure can relate to the tolerance of the lamp housing, shade etc again down to heat tolerance. I see no problem fitting any size CFL lamp in a standard lampholder unless the fitting is designed for CFL lamps and the control gear is not contained within the lamp but external (usually in the fitting itself) in this case the control gear will be rated for a specific lamp size.
