change a single socket to a double | Page 2 | on ElectriciansForums
Discuss change a single socket to a double in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thats just bad crack!!! you are not alltering the wiring in any way a double counts as single on the test sheet when you add up number of points!! you are just ripping folk of to do a test! do a end to end test before connecting the socket and a zs at the end( TAKES ROUGHLY 5 MIN TOPS) if you are really unsure about how your connections are at the socket???? but a would not see the point of a MWC, just for you rip of merchants !!!!! makes me sick 10 min job into a hour for a socket!!!!:mad:
Inspection and testing is essential.
End to end test proves what ? Continuity only !!!
Any circuit you work on could have reversed polarity at one point and the only way you can prove it is with the 3 step tests.
Cowboys make me sick. Cheapens the trade and your worth. :mad:
I would always fill out a minor works cert to be honest, if not simply to prove that you've done the appropriate testing to ensure the circuit is left safe.
I suppose it's an 'arse-covering' exercise.
And if your customer receives a nasty electric shock shortly after you replace a socket, and sues you, where is your defence if there is no certificate ?
If you've done the required tests to check it's safe anyway, why not make things 'official' by chucking the measurements on a minor works cert ?
Surely your only defence is a proper certificate issued to the customer with you keeping a copy.
Reply to change a single socket to a double in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It depends on where that SFU 'sits' in the circuit. If it's there as a courtesy isolator for the fridge socket then potentially yes as it could...
If the OP could DM you with that info? Rough area is fine, but don’t post your full address in public, obviously.
