View the thread, titled "changing a bathroom extract easy???? NOT" which is posted in Australia on Electricians Forums.
HELLO ALL,
i attended a customer with a reported faulty bathroom fan. It was the timer variety with a three pin connection.
I checked the pins and found there to be 240v present so i determined that the fan must be shot. 30mins later i get back with the new fan and connect up but it did not work.
the fan i baught was a ASX100T from greenwood air managment, (a good fan)
there is a three pole isolator switch on the wall outside
and of course the bathroom light switch
at the isolator there are three cables grey, black and brown
now here's the funny thing
when the light switch is closed and the lights are on, the black wire from isolator to the fan is the ony live cable
when the light swtich is open and the lights are off, the brown wire from the isolator to the fan is the only live cable.
from my understanding of the wiring diagram, in order for the ASX100T to work i need a switched live and a constant live.
So am i missing something?
Anyhoo i did try to access cables to rewire accordingly but they are hidden behind a suspended ceiling and access can only be gained by removing this ceiling which is not a real option as of yet.
!- any idea why the circuit is wired up two switch over live from one core to another - could it be a fault or was it supposed to be like that?
2- what options do i have to get the new fan SAFELY working.....
i have included the wiring instructons for the newASX100T fan (1st column 2nd row)..... asx100t.jpg
thanks guys for all your help
DD368
Gentlemen, if we have guys using different coloured cores for lives and switch lives and even neutrals how can we be expected to understand WTF someone has done. Niceic printed cable colours along with many other publications. Old colours were RYB - live/switch live/neutral and new colours BR/BL/Gry so brown = Live: Black = switch Live (sleeved brown) : Grey = Neutral ( sleeved blue) Simples!
That's all well and good if you're signed up with NIC, but wouldn't it be better if the use of specific coloured cores in various typical situations was explicitly recommended in BS7671 or even the On Site Guide (I'm sure someone will correct me if it is). Although, of course, you use sleeving I really think that they missed a trick when amending the regs.
They should have made them all grey or whatever, preferably a colour not in the old scheme so you knew they were new, and you have to sleeve them with a uniquie colour that identifies them as specifically L1,2,3, switched live, N, etc. That way, there is no confusion. All you have to do them is worry about who sleeved them, but a quick check would verify what they purported to be. Which we all do anyway.
And if they were not sleeved, it would force you to check them and not trust what they purported to be too.
Having colours that can be used for various uses, is just loose regulation, especially when they went to all the trouble of changing.
need colour id....otherwise you`d spend more time bellin em..lol....
Reply to the thread, titled "changing a bathroom extract easy???? NOT" which is posted in Australia on Electricians Forums.
