Changing a Halogen kitchen Unit lamp!!!! | on ElectriciansForums
Discuss Changing a Halogen kitchen Unit lamp!!!! in the Australia area at ElectriciansForums.net
C
caithpal
Okay i have the attached halogen fitting above the sink in my house - 3 off.
One has blown - how do I change it? I can't remove the glass and it doesn't seem like I can change it from above? Any ideas?
Thanks in advance!
  • [ElectriciansForums.net] Changing a Halogen kitchen Unit lamp!!!!
get a small flat head screwdriver to prize open the bit that holds the glass from the fitting using the four little holes you can see then just slide the bulb out from the 2 pins.
Reply to Changing a Halogen kitchen Unit lamp!!!! in the Australia area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
