Changing ceiling rose in a new build house | Page 2 | on ElectriciansForums
Discuss Changing ceiling rose in a new build house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Using brown and blue makes identifying the switched live much easier, and saves carrying two lots of cable around.
I've never had a problem with twin brown. Anyway, it is often irrelevant which one is the switched return for the phase conductor (e.g. 1-way switching).
What a load of cobblers.
How is it cobblers. BS 7671 states that identification of conductors are "preferably throughout their length". So there clearly is a preference stated.
Here many would make you rip it out if you installed brown & blue (even if it was sleeved). It is considered bad practice here. And if I drive just 1.5 miles and cross the border it is expressly prohibited.
Because its bloody obvious to anyone that if its a switch drop both conductors are likely to be live. Sleeving is perfectly acceptable, IMO.
Out of interest, what do you do for a two gang switch? Do you use a three core and sleeve the black and grey or would you run a twin brown and a single?
Almost always twin brown for strappers and singles either end (presuming you mean 2-way).
Although some use 3-core, I would say the majority don't. Again, across the border the use of 3-core (or three-phase cable as they describe it) is not permitted.
OOeerrrr
I meant a 2 gang, 1 way. So I would run a three core from the rb4 to the switch, brown for common and black and grey for the two switched lives
With a 2-gang 1-way just a twin brown from one of the luminaires, and then a single to the other luminaire with the commons bridged in the switch.
Which wouldn't happen over here as we don't have sheathed singles available.
So for me it would be a three core to the switch from the rb4 and a twin to each light from the rb4
Reply to Changing ceiling rose in a new build house in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
