changing cu with no cpc in lighting circuits | Page 2 | on ElectriciansForums
Discuss changing cu with no cpc in lighting circuits in the Australia area at ElectriciansForums.net
flukey
Basildon, Essex
hi all,
got a cu to change on mnoday where both lighting circuits have no cpc.
done a few before and nearly always because home owner wants to keep price to a minimum :rolleyes:
i obviously mark it on eic and correctly label the cu so it all complies.
just wondered what others thought regarding this scenario as im not turning any work away at the moment :p
I know this may sound a bit thick:)
But I thought generally the regs prevent us leaving an installation less safe than it was previously.:confused:
I know what the ECA guidance is on earthing to lighting circuits - but wouldn't installing a new CU with RCD protection actually make the installation much safer than before?
Although I know that the entire installation should be tested before installing the CU, I thought that the EIC would cover the CU work only??
This isn't a major problem for me as I will just follow the ECA guidance.
I just wondered whether anyone could explain???
Cheers
Reply to changing cu with no cpc in lighting circuits in the Australia area at ElectriciansForums.net
