All in and secure.
Not all the earths fit in to the standalone terminal but they are all twisted together and taped with electrical tape. Is that going to be a problem?
This is the 4th ceiling rose I've installed, but ipf has put the fear in me given that this is in my unborn child’s nursery.
That's nearly as much a mess as it was previously.
Just because it works, doesn't mean it's correct.
Advise you get someone in.
The connections are not great and the cables should enter the rose. Poor connections can have consequences so professional help is required, an hour's work max and peace of mind.
….not to mention the rose not being fixed prior to connection. Fixing would, almost certainly, result in cable and termination damage.
Have you connect the earth cable from the brown and blue cable to the earth terminal? , as others have said you should of secured the light fitting to the ceiling before connecting it up.
Don't forget your intumescent gasket to fit behind the rose before you secure it to the ceiling or put the wires in.
I personally didn’t think it was that bad, but then again I’m not a professional.
It may seem like everything is connected, but poor terminations can work loose eather when you move it to fix it up or later on due to expantion and contraction with the heat, vibrations etc.
It is these poor connections (which often work still) that can overheat due to high resistance and eventually cause a fire. It's less likely in a lighting circuit due to the low currents involved, but not impossible.
All in and secure.
Seriously, that wiring is not to standard. Poor terminations cause fires. I'm sure it works but please get a sparky in to do it properly, it should literally take 15 minutes to make it safe. Maybe also get him/her to check the other wiring you've done previously as well.
not in this case. a house is 1 fire compartment in itself. .
Changing light fixtures (wiring mess)
Thread Tags
asweby,
telectrix,
