Changing old triple 2 way light switch to New triple 2 way wiring set up problem | on ElectriciansForums
Discuss Changing old triple 2 way light switch to New triple 2 way wiring set up problem in the Lighting Forum area at ElectriciansForums.net
patsy59
torquay
The switch operates an outside light ,Hallway Light and two way landing light I want to change to new socket but the set up is different in the old switch . I was hoping to copy from the old switch but am stuck any help on what wires go where on new switch would be helpful I attach three pics two of old one of new
  • [ElectriciansForums.net] Changing old triple 2 way light switch to New triple 2 way wiring set up problem
Just look at the 3 switches as 3 separate devices, noting the the middle switch is upside down.
Common on top and L1, L2 bottom.
Be aware that there is no connection between the landing 2 way and the other 2 switches. It may be on a different circuit.
Also you will need an earth wire between the metal back box and the metal switch
Just follow the labels (L1 to L1, Com to Com, etc)
Reply to Changing old triple 2 way light switch to New triple 2 way wiring set up problem in the Lighting Forum area at ElectriciansForums.net
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
Thanks again for your help, now solved đź‘Ť
