T
Tate
I have to rewire in a mains fail relay that will inform us when REC power has been restored.
At the moment we have REC supply leading to changeover siwtch that is fed by the REC or a generator. The mains fail relay is upstream of this, so will indicate mains on either REC or generator.
I would like to wire the MFR so it informs us when REC supply is back only. This would involve connecting a 2.5-4mm single between the incoming side of the changover switch to an MCB that would inturn feed the MFR.
Are there any regs that say this is a no no?
Cheers
Cheers
