charging multiple electrical devices | Page 4 | on ElectriciansForums
Discuss charging multiple electrical devices in the UK Electrical Forum area at ElectriciansForums.net
David Waterman
Hi,
I am frustrated by the lack of electrical outlets in my bathroom. I realise there is an electric shock hazard and that is the reason behind this problem. However, I don't see why I can't plug all my devices in at the same time so they can charge, even if they charge one-at-a-time. Isn't it a simple enough matter to time share the supply to multiple plugs?
Is there some risk I'm missing here?
I find myself also wondering why things like shavers and toothbrushes can't charge via a USB outlet too. Of course, I'm presuming there that the risk is lower from a USB socket than the usual one - I know many USB chargers can supply quite a lot of current, and even at 5V that is probably some risk, but they don't have to supply a lot of current, I imagine.
What do you think?
Max.
Well the customer is always right. For me the only thing I have on charge in my bathroom is.........nought. Her indoors got her toothbrush plugged into shaver socket once a week, I binned my electric shaver (which only need charging once a month, shaved every day, don't you know), for more manly wet shaver.
But if people want to usb plug in there iPad, iPhone, watch a tv in the bath, hair remover, hairdryer or whatever else, pamper their needs. Personally, wandering around in the nudy :eek:, with lashings of water & steam abound, I rather just manually teeth with a toothbrush. :)
here's the answer.
[ElectriciansForums.net] charging multiple electrical devices
What a bloody daft thread, it does not happen here in the UK. Forget all that 3 meter rubbish.I for one would never even fit a switch inside a bathroom, pull cord or it goes outside, never mind a socket.
I'm with you on that one Dave. Sensible way to go.
Reply to charging multiple electrical devices in the UK Electrical Forum area at ElectriciansForums.net
You won't fall fowl of anything you are installing a 32A socket it is up to the user how they employ it.
Gents has anyone done an application using the UKPN smart connect portal for a split phase supply and addition of multiple single phase battery...
