chasing concrete walls | Page 2 | on ElectriciansForums
Discuss chasing concrete walls in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If the internal Walls are really thin, I try and offset back to back sockets so you get at lest half a boxes width supported by wall even if you do go right the way through on the bit that is directly behind the other socket.
And people think electrical is easy , the amount of engineering thats some times requred is unbeliveable
second that , nick. had to fit a remote control fan in a conservatory. nothing to fix to. ended up fabricating a clamp out of unistrut, zebedees and threaded rod. 4 hours to fit a fan!
Dot and dabs ok when done with a decent amount of dabs. Its when you get a wall with 8x4 sheets and only 6 dabs that its becomes rubbish IMO.
Worked on a house once a thought the wall was a standerd stud wall as when tapping the board the wholes board flexed, cant believe the board stayed stuck to the wall as hardly any adhesive had been used.
Reply to chasing concrete walls in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
And if it's a garage then use metal clad accessories.
