Cheap AFDD implementation in flats. | Page 2 | on ElectriciansForums
Discuss Cheap AFDD implementation in flats. in the Electrical Engineering Chat area at ElectriciansForums.net
Status
Not open for further replies.
I see no complexity in the wiring.
Understand what I put. These dwellings being in London are likely to have complex wiring money would not be an issue. I am not referring to your suggestion.
You are guessing.
The aim is an AFDD installation to regs at minimum cost.
You are guessing that money would not be an issue. Money being an issue or not, the aim is an AFDD protected installation to regs at "minimal" cost. If you can suggest a cheaper method please do.
Say a block of 60 flats in a 6 floor old block renovation like seen in London mansion blocks. All flats have gas heating. Costs are then dramatically cut for the electrical installations giving full protection.
A job like that will be designed and specified by someone in a design office. They won't have any concerns over the cost as they will just be getting paid to do the design so it can be put out to tender. They will design it along standard lines and specify an AFDD for each circuit that the regs require them for, they may even go further and specify an AFDD for every circuit just because they can and it covers their backside.
The job will go out to tender and whoever wins the job will follow the design spec, if they don't and decide to cut costs following your method they will get called back and have to change it to meet the spec at their own cost.
Status
Reply to Cheap AFDD implementation in flats. in the Electrical Engineering Chat area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
Are you sure the existing outside socket is on the ring, and not already a spur? I tend to place a switch fuse on the ring inside so that the...
