Cheap horrible fittings | on ElectriciansForums
Discuss Cheap horrible fittings in the UK Electrical Forum area at ElectriciansForums.net
B
bigbaddave
Just turned up to complete a second fix of a rewire and for the first fix used a batch of back boxes i had in stock i got from a screwfix clearance for pennys...
Anyway... There was 20 in total. All installed and then the plaster had been in and dot and dabbed.. All good.. Untill I came today to do second fix and every back box when i went to screw the facias back the lugs came off. When i looked they were all the same nothing keeping the lug from coming loose..
Moral of the story you get what you pay for.... For saving less than ÂŁ10 has cost a lot more in time and diesel..
Anyone else got horror stories with cheap gear ?
Bought a pack of plastic capping from screwfix, every single nail i used cracked right through the capping, made a right mess and added hours to job as in the end I drilled and screwed most of it up.
I think we've all been in that position at one time or another mate. My wake up call came when I bought a load of cheap GET double sockets, they installed OK, but over a period of months the screws sheared and/or the back of switch mechanisms cracked, so many call backs for switching or socket faults it made me quite dizzy!
Reply to Cheap horrible fittings in the UK Electrical Forum area at ElectriciansForums.net
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
