Chernobyl does anyone remember it?
I was still at primary school at the time and although I heard it mentioned nobody bothered to explain to me what was going on.
I have played Fallout 3, Fallout 4 and Fallout New Vegas though.
An ex girlfriend was from Moldova. Her parents moved there from belarus before the collapse of the soviet union.
Belarus had it bad from the fall out. My ex's cousins would regularly go to moldova for a few weeks each year as the time away from the home town across the border from ukraine would do wonders for there health apparently. As the radiation is still above normal and there is a abnormal rate of bone and birth deformities in there town in belarus. Polina my ex said her parents told her about it and they were kept in the dark for weeks before learning the truth. Apparently in belarus the authorites slaughtered loads of live stock and food was hard to come by amd had to be shipped in from further afield as most of the stuff growing in belarus and ukraine was too contaminated. It really led to bad poverty that was hidden from the west. her dad decided to seek a job in Moldova in a steel wire factory. He got the job and thats when they left ukraine with my ex born in moldova in 92. Polinas dad use to say though that it wasnt chernobyl that they worried about now but asbestos that most of the soviet high rises in chisinau were full of.
You want to try VR tour of Prypyat if you cannot go to the real thing, it is extremely disturbing seeing a ghost town taken back by nature.
Agree with that, I've watched loads of videos about it on YouTube. Wouldn't like to get dumped there on a dark night.
I visited Loch Buie on the Isle of Mull a couple of years later, and it was clear that some fallout had had an effect there on the livestock and the ground-cover.
For anybody that is remotely interested!:D
Since the 1st atomic test at Alamogordo in New Mexico, there have been more than 2000 other tests. There have been over 200 small to large accidents at nuclear facilities since we have started tinkering with the atom. Currently there are more than 400 nuclear reactors in operation around the world. Not counting the ones floating around in space powering satellites etc. 65 new ones are under construction and another 165 in the planning stages.
Radiation is different from things like poison in that it does not accumulate within the body. What determines your odds of survival from radiation poisoning is primarily your livers ability to break down the poison. The reason not everyone dies at the same dose is because of the variations of each person's body. As the dosage is increased the odds of surviving becomes smaller and smaller until you reach the limit of what the body can process. At a certain point you will have a dosage that no human can survive. Most low dosed ionization radiation poisoning presents itself in the form of cataracts in the eyes, smaller brains, malformation of sperm or complete sterility. So if your best buddy down below is rotted away at an alarming rate, you now know why.:)
Now, with radiation it's not a matter of health, but purely an exercise of luck. Alpha, beta, and gamma radiation all damage the body in the same way. When a particle or a wave collides with your DNA in such a way that the cell can not survive or it disrupts sequencing then that will cause cancer. We're exposed to the cosmic background radiation every day and each individual particle/wave of radiation in your everyday life is no more or less dangerous than the radiation from a nuclear bomb. Imagine you're laying on a football field and someone in the stands is blindly throwing needles onto the field. It's unlikely that the needles will hit you, and even less likely that the needles would kill you. However if you have say 100000 people each throwing needles onto the field it becomes much more likely that you will get hit by one and likewise more likely that one of the needles will hit you in such a way as to be fatal. Because this is a matter of luck and not a matter of health there is no hypothetical limit to the number of needles that can be thrown onto the field, or the amount radiation a person can survive. Your odds of survival may be infinitesimally small, but there will never be a point where the odds of dying are exactly 100%. Caveat to that being the point where the radiation itself imparts so much energy into your body that you are physically torn apart or burn up. But if you're ever in that position there are probably a dozen or so other things which would have already killed you, so I wouldn't worry about it.:)
And just as a little side note. The technology for the MRI scanner was developed at CERN, and uses radioactive material that comes straight out of nuclear facilities. And if they weren’t using it inside the scanner at the hospitals, it would be deemed nuclear waste.:)
I would agree with the statistically affective nature of ionising radiation.
However MRI scanners use a technology adapted from a chemical analysis technique, Nuclear magnetic resonance, this is the application of high power magnetic fields and an oscillating radio frequency to affect the energy state of the spin of protons, what part of this contains nuclear material?
An MRI scan does not emit or use ionising radiation as part of the measurements.
Just following on from Kamikaze's post .. Radiation poisoning is actually an oxymoron as he goes on to explain, to add to his post and the points he made - when our bodies cells divide and multiply they do so with an inbuilt timer for there own demise IE a death switch, this ensures the coded sequence is kept as good as it can be and genetic errors in the dividing are not continuously repeated - radiation is a double whammy as it can damage the genetic code and also switch off the natural kill switch of cells which leads to many annoying or life threatening issues.
Cancer is just that and is caused by several factors from the solar radiation (skin cancer often a result), environmental factors, chemical/toxin exposure through to good old genetic flaws passed down to you.
Many people see cancer as some form of disease they catch but it is more so there own bodies genetic code been damaged and replicating the damage until it is either stopped or leads to ones demise.
Pete999,
Squid,
