Installed a new radial circuit in a garage from an existing CHINT garage unit.
All functioning well (tests fine) until after the RCD test. Then everything, lights etc stops working.
On investigation, while I've got 244V at the incoming side of the main switch I'm getting a reading of between 85 and 166.5 on the outgoing.
Guessing it's knackered the RCDI'll swap it out tomorrow but wondered if anyone else has encountered this fault. I've never touched CHINT gear.
