The problem is that it often appears that some posters are not electricians but DIYers, especially when they don' answer questions regarding their OP's.
After many years of various online gaming forums (especially WoW forums) this place is far far too tame to even compare with nastiness and trolls.
Best thing to do is sitback, chill about then post a reply when someone's got your back up....admittedly i dont always follow my own advice but on the whole it's when you bit back that threads got to ****e.....basically dont give 'em the ammo to load thier guns.
Played Wow from launch until WoTLK was released.....all became the same old same old so very unlikely i'll return in truth...dont like Panda's
I had 5 or 6 alliance toons 3 of which I'd maxed to the end of Wotlk on arathor and 1 horde on bronze dragonflight. When MoP is released, as I say, I'll more than likely go back and max the rest
I personally think the tolerance has gone as more and more the same simple stuffs getting asked, rather than using the search first.
I tried the search. it ain't that easy unless you put in the exact right words to the thread
Just read this thread from start to finish and now I've forgotten what the original question was lol
I've got to install a CU for an old fusebox.Problem is, there's not enough space for a split load CU.As I've only got 7 circuits, is it alright for me to put a unit in with 1 RCD that protects all the circuits?
Do you have all of the dimensions for the cupboard?
If you could post up what space is available perhaps a kind member may know of something that will do just the job:thumbsup
"I" personally would never fit just one RCD covering an entire installation.
Two reasons automatically spring to mind 1) If there is a fault on a single one of the seven circuits the entire installation will be wiped out, you know only too well this is more than likely going to happen at night leaving the house in complete darkness which will put the client at risk of injury due to not being able to find their way in the dark.
Second reason that also springs to mind, a build up of earth leakage over the 7 circuits may cause nuisance tripping of the RCD device.
I would most definitely try to encourage your client to opt for RCBO's however, this can get expensive as I am sure you have already realised.
There are other ways of not requiring RCD protection but IF steel earthed conduit is not already in place or cables buried not less than 50mm in walls then this work will far outweigh that of providing RCBO protection.
PS, I've had a wonderful weekend away and not been on the forum to read any other threads or get wound up by the many trolls that visit the forum so out of the kindness of my chilled heart I have provided what I believe to be my most informative reply.
PS There is a like button in the bottom right corner of this post and a Thanks button on the bottom left.
Please post back and let us know the dimensions and keep us updated with your progress,
Good Luck and Welcome to the forum:thumbsup
:D
chnaging CU
Thread Tags
electrician4u,
Geordie Spark,
