Discuss choosing cable voltage rating in the Australia area at ElectriciansForums.net
you select cable so as the rated voltage is higher than the actual voltage of the installation. no point in using 1kV rated cable on a 415/240V installation when 450V rated is compliant.
Reply to choosing cable voltage rating in the Australia area at ElectriciansForums.net
