Hope someone can clear something up for me.
I've been selecting cable recently to wire up industrial machinery for test purposes only.
I usually purchase H07RN-F or H07BN4-F.
My boss has informed me that the cable needs to have a current carrying capacity to match the supply it's being being connected to. For example if the equipment is being connected to a 415v 32a supply the cable in the case of the H07RN-F needs to be 6mm irrespective of the load.
Say the load is known to only draw 3A I have been selecting lower CSA cable based on the load requirements of the equipment but he says that if I do this the cable should be protected by a suitable breaker.
I do a fair bit of pat testing and often see equipment with 2.5mm h07 cable connected to equipment which has a 32a plug fitted.
Is he getting mixed up with installation cable selection as opposed to selecting suitable cable for equipment.
If I'm making an extension lead I always use 6mm cable as It should be capable of carrying the full 32a as I don't know what will be connected to it.
Are there any books I can read on equipment wiring.
Sorry for the long question just really would like to clear it up.
