Circuit Metering | Page 4 | on ElectriciansForums
Guest viewing is limited
Discuss Circuit Metering in the UK Electrical Forum area at ElectriciansForums.net
Wales
Hi All
I have been asked to install a New DB to serve 40 offices, with the facility to meter each office individually.
I was thinking of installing a 18way TP&N DB, running 10mm to each office where a smaller SP CU is installed branching off to 3 circuits. Lights, Sockets and electric heater. A Din Rail Energy Monitor would be installed in this CU.
Whole install is in Dado and plastic trunking on the surface so RCD is in the office CU and not the 3P&N DB.
Any thoughts on this or any other way of doing it.
theres 40 offices, so needs to be 16 or 18 way TP&N
Theres 28 offices (current) but will probably reduce to 20 in total being supplied off this board
I don't have my copy of the BYB to hand but I think this is technically called moving the goalposts.
Reply to Circuit Metering in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
Recommended Sponsor News
Hi everyone,
Wales
Circuit Metering
