circular or plunge cutter | on ElectriciansForums
Discuss circular or plunge cutter in the UK Electrical Forum area at ElectriciansForums.net
M
mdgibbs32
Hi lads and ladies
Anyone used the Bosch GOP10.8V-Li L-Boxx 10.8V Multi-Cutter (or similar) for floorboards etc
i used to use a circular saw but its just died and was thinking of one of these instead
does it have any other uses
in other words is it worth it
thanks folks
It's a lot more accurate than a circular saw though blade use is expensive. Circular saws have their place as do "multi-cutters". The big advantage I found with the multi cutter was that if there were CH pipes notched in joists, you stand a chance of feeling the copper before feeling the water.
They are a godsend in domestic. I have a bosch one, mains operated, as the 10.8v lith ones eat batteries. Brilliant for floorboard edges, sinking dryliners in lathe and plaster, taking individual tiles out etc etc. Not often I find a tool nowadays that I wonder how the hell did I manage without it but this is one
I agree that circular saws have their place, but I use the Fein multitool 230v, and I can't coun't the times it has been a lifesaver. The Fein blades are expensive tho', but there are cheaper alternatives. Like TaffyD, I wonder how I managed before I had this!
Regards
I have both kits and the multi tool would struggle on chip board floor, best to use a plunge cutter and go at intervals with the depth if you're scared of slicing anything below.
My Multi cutter Is a weird brand called pure but it's brilliant and the same batteries of Bosch ones. Theses are good all Christmas presents....i
and you do with the circular saw n all Jeremy....if you bother to set the depth of the blade that is....lol.....lol...
I have got the makita multi tool its brilliant, very neat cuts and thin so looks good when the boards are replaced and you dont cut the boards next to the ones you are lifting and you can cut right up to the skirting boards. new blades are quite expensive though.
cannot stress how good they are, it's paid for itself many times over in saving me time doing jobs. i have the makita 18V one, it's just as powerful as the fein 230V one i had before. blades are expensive but think of the time you are saving. also, i have been using some really cheap blades from aldi recently, about as good as the shark blades but loads cheaper.
i have the bosch gop 10.8 as said battery's are useless,i bought the gop when oscillating cutters first came out i then bought a worx sonicrafter mains version it munches through wood cracking bit of kit,you can use the Bosch bits in a worx if you get a 2 quid adaptor off the bay,you can also get good deals on blades if you look carefully
Reply to circular or plunge cutter in the UK Electrical Forum area at ElectriciansForums.net
