Just thought I'd check the HMRC website on this
Solar Panels
The installation of solar panels to provide solar heating will be a construction operation within CIS, except where the contract is directly with a private householder.
So if we're doing solar PV that's not for solar heating, right? (Assuming no Immersun!) And also for all non-commercial jobs we shouldn't be doing CIS either. Does anyone else interpret it this way?
Just seen another thread by BruceB about this. Now I get it, the exemption is when the sub contractor has a contract direct with the householder so that wouldn't work for us. And in his post there's also a letter from HMRC stating that PV is a new power source, even though it's not solar heating. Guess I'd better crack on and do my CIS return then!
I've recently had to deal with CIS, first commercial job, they're deducting 20% etc. (ouch)
I did read though that they should only technically be deducting the 20% off the labour, Might be worth popping this over to the SL
You're correct the 20% deduction should exclude materials
