CK Automatic or Irwin Vise Grip Wire Strippers? | Page 4 | on ElectriciansForums
Discuss CK Automatic or Irwin Vise Grip Wire Strippers? in the Electrical Tools and Products area at ElectriciansForums.net
Think these tools are good if you Are panel wiring etc with fine stranded wire, with many multi core cables to strip , they make a perfect strip and never cut into cores , not that you should if you are a skilled electrician
But for everyday sparking a bit OTT in my opinion , but each to their own and why not use them
I prefer to use not snips/side cutters but what we call crops or shears think the trade name is , the ones with the curved cutting edges , can’t beat them in my personal opinion
I found them to be no use for fine stranded wire.
Squashed the insulation and cut into the cores.
Hi I went out and took a gamble on the CK Automatic Strippers because they were going for £15.45 at my local Toolstation.
They cut the sheathing off 2.5T&E without any issues and I can do whatever length I like if I remove the stop guide.
I have to say that I am impressed and they will save me a lot of time and protect me from gouging my hands.
The only downside is that the cutter is not too great and they tend to leave jaw marks on the cable.
I'm not a professional sparky so this tool is a god send when it comes to removing cable insulation and getting up to speed.
They will certainly do for now.
Here are some pics.
[ElectriciansForums.net] CK Automatic or Irwin Vise Grip Wire Strippers?
Jaw marks on the cables.
these style of strippers will always leave jaw marks. as long as the don't cause any damage or compromise the integrity of the sheath, no problem.
That's what I was thinking.
They leave 4 teeth marks on the cable but I don't think that they are deep enough to compromise its integrity.
It just looks less attractive than not using one if you see what I mean.
I personally recommend the CK strippers. They are great quality and very reliable, working from 6mm CSA down to 1mm CSA perfectly.
have both the CK and the Klein. not that much in them but Klein just have the edge .only gripe with both is that silly strip gauge. gets in the way. best ripped out.
Much, much less time than using a knife. And zero chance of nicking the insulation.
Depends entirely on what sort of knife you use, I would agree with you if you used a Stanley type blade, but I have been using a folding knife since day one of my electrician life, and apart from the odd mistake when I was an Apprentice, I have had no slip ups, but what ever rocks your boat.
While I agree there is no chance of nicking the insulation with the automatic strippers, with certain T&E it can not only strip the outer sheath but take the insulation off the inner cores at the same time:(
Reply to CK Automatic or Irwin Vise Grip Wire Strippers? in the Electrical Tools and Products area at ElectriciansForums.net
I'd go for strippers every day, wire and cable are just plain boring! Definitely get yourself a stripper! (Failing that Id use ck crops)
I'd have thought this is way more risky in catching the inner insulation and definitely slower
