Class 1 fittings | on ElectriciansForums
Discuss Class 1 fittings in the UK Electrical Forum area at ElectriciansForums.net
grumpyjohn01
The Sticks, Dorset
I am working with a lighting designer at the moment producing custom light fittings for a restaurant chain. Most of his designs are raw metal (steel, copper,brass) welded or riveted together with brass lampholders and 'vintage ' 3c flexes. All the lampholders are earthed via their dedicated terminals and are fixed to the fittings via 2 brass shade rings either side of a hole in raw metal. Tightened with a wrench I am achieving very good earth continuity to the whole fitting. Does the panel think a separate earthing terminal is required elsewhere on the metalwork? Instinctively I think yes, but as I say cont is v good and the onsite contractor fitting them is satisfied so......? thoughts please !
The 3core flex you're using I'm guessing is external to the fitting, as you're fitting 'vintage'
So in answer to your question, although i'm not sure if i've disected your OP properly, is Yes ... otherwise how else are you going to connect the earth that comes out of the ceiling ? Have you got access to the nut and bolt when installing the fitting?
Also you say you're drilling holes in these fittings ... you have to be careful with ridged edges and flexes, grommets probably will be required.
Also, are your fittings BS ? And are the flexes also ?
All the electrical parts are high quality & to the relevant standards and yes the flexes are external. All the holes are laser cut with radiused edges . 'The earth that comes from the ceiling' as you quaintly put it is connected to the lampholder & the lampholder is connected to the metalwork (via its body and shade rings) or 'shade' as I am now going to equally quaintly call it!!
Thanks for the info on the relevant standard, I shall order one immediately, unless anybody has a link to a pdf?!
It's not cheap but it should give you all the information you need - BS EN 60598-1:2008 - Luminaires . General requirements and tests ? BSI British Standards
Attention will also need to be paid to how you will test your end product - multimeters/PAT testers don't generally offer the specifications needed to comply with manufacturing standards like the above.
Reply to Class 1 fittings in the UK Electrical Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
The manufacturer has stuck a label on the baseplate, its clear to see. I don't know what instructions came with the fitting or what was written on...
2 3
