Class 1 with no earth? | on ElectriciansForums
Discuss Class 1 with no earth? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Manchester
Hi, I'm new to this so apologies if the answer is obvious! I'm PAT testing a coffee machine as a class 1 as there's nothing on the label to suggest it's a class 2 but when I test it, it says "no earth". Why could this be?
These machines often have inaccessible Class I parts and any external metalwork is essentially isolated from any internal electrical parts.
often one or 2 screws are attached to some earthed metalwork inside, it is worth doing a quick continuity test to them.
Reply to Class 1 with no earth? in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
out of interest UK, how do you know what kit is connected?
As said above by @pc1966 at least do that earth test. I'm finding that increasingly we need to check fixed appliances connected to FCU etc as the...
I am also the customer here which makes it easier! - I am the technician in the school, who has just started doing the PAT testing too.
Its ISITEE and PAT testing are the same, they are moving away from the word PAT testing as it confuses people.
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
