Click plugs question | on ElectriciansForums
Discuss Click plugs question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Adam_92
Trainee
luton
Can these click plugs be hidden in a ceiling or do you need an access hatch to get to them.. can’t find any regs on them
Building is a container and it splits for transport?
Thanks in advance
  • [ElectriciansForums.net] Click plugs question
I would ensure any interlinks between parts of a modular building were accessible for inspection/ maintenance
also to enable easy connection and disconnection when transport is required
These sort of click / plug in connectors are designed so the person changing a light can do so with ease. IMO they need to remain easily accessible and easy to reach at all times
Reply to Click plugs question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks, it says under the picture of the 4 front plates (in the tiniest writing possible) "Excluding the definity grid pro front plates which do...
A lot of issues can be solved by giving the connections an extra push with the back side of a Stanley blade if they haven't quite mates properly.
davesparks
