View the thread, titled "Clients requirments" which is posted in UK Electrical Forum on Electricians Forums.
G
Graham Coughlan
The client has specifically requested three phase fan units to be fitted, each appliance draws a current of 8.67A from a 400v, 50hz ac supply.
One appliance is wired using 21m of multi core 90°C themo-setting insulated non shealthed cable.
The circuit is protected by a triple pole bsen 60898 mcb type c. The cable is to be incorporates into pvc rigid conduit fixed surface mounted in an area where ambient temp is 40c.
The conduit will also partlynbe used for 6 x 2.5mm2 standrd single pvc cables...
Ive gotta find...
1 the rating of the protective decive
2 the relevant correction factors
3 min cable size required
4 max size of cable
5 max permmited volt drop
6 actual volt drop
Reply to the thread, titled "Clients requirments" which is posted in UK Electrical Forum on Electricians Forums.
