Coaxial Cable Recomendation | on ElectriciansForums
Discuss Coaxial Cable Recomendation in the Electrical Tools and Products area at ElectriciansForums.net
David Prosser
Nearly Esteemed
Patron
UK
Will be putting in a new aerial and outlet point in the lounge and didn't like the look of the cables in screwfix. Was just wondering if any one had cable they would recommend ?
Thanks I will only be putting the outlet in the lounge.
Any idea of what size that cable is ?\It was the rather weedy look of the cable at Screwfix that put me off.
Reply to Coaxial Cable Recomendation in the Electrical Tools and Products area at ElectriciansForums.net
You don't ! You either get another dual connection plate, or if only one cable is actually required you wire that one to the single plate and...
It's galvanised and provided you coat any cut edges with galv spray there should be no signs of undue corrosion any time soon. Galv trunking...
nicebutdim
N
