Code 2 for non RCD lights in a bathroom | on ElectriciansForums
Discuss Code 2 for non RCD lights in a bathroom in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
UKMeterman
Hi,
I have had PIR done on a flat that was built in 1991, I have had a code 2 on the lights in the bathroom not on an RCD even though it is an IP 56 fitting, is this correct? The maximum demand has also been put at 50KVA for a 2 bed flat...!
code 4 for the bathroom lights, as long as there is no apparent danger. 50kVA is probably he meant 50A.
The bathroom should have either RCD protection on all circuits or supplementary bonding.
If SB is in place then lack of RCD = code 4
If no SB in place there should be two coded items:
No SB = code 2
No RCD = code 2
IMO
Has the supp bond box been ticked on the schedule?
ive allways worked on the idea of a pir/eicr is to evaluate the installation against the CURRENT version of the regs, if the install was to an earlier version of the regs then issues such as above would be a code 4 but now what would they be a C3 or no code??
I have no idea what they didn't like about your coding, maybe they had cause and maybe not!! But they can't and/or shouldn't be telling you how THEY want it done!! You follow the national guidelines laid out in the relevant authorities, which i guess would be the IET in this case...
Just to put a spanner in the works.
Whilst the IET along with the BSI, has the responsibillity for conceiving, formulating, writing and publishing the Regulations.
In actual fact, the NICEIC, along with representatives of just about every other electrical organisation provide members of the comitee that does the work.
So technically the NICEIC do write the Regulations, or make the rules.
Reply to Code 2 for non RCD lights in a bathroom in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
