coffee machine on a timer | on ElectriciansForums
Discuss coffee machine on a timer in the Talk Electrician area at ElectriciansForums.net
M
moe
hi.. just wondering what would be the best way to do this... the coffee machine is on a 240 supply with a radial circuit going to it on a 32 amp breaker, with a double pole switch at the end.. the customer has asked if i can put this on a timer to come on half an hour before they get into the shop??...
thanks
timmer controled contactor is the any real way to do it if it is such a heavy load,but you should check Zs to see if you can put it on a C type breaker in case of it pulls alot first thing
Whats the electrical requirements? Is that radial circuit suppling only the coffee machine? Ive seen a large commercial coffee machine that was 2KW. In such case an immersion heater timer would be fine. For larger loads you could use timer to switch a Relay contactor. or timed contactor. If your not sure of supply then clamp it.
thanks... not sure of the load just had a quick look at it on the way home, am going back tomorrow... was thinking of a relay contactor and a switch, not 100% on how to wire it in, any help?
not to sure on the csa yet, just had a quick look and now it is powered off a phase of a 3 phase system on a 32 amp radial so pretty sure it's pulling quite a bit... the installation is also new so pretty sure the correct mcb was asigned.. sorry for pretty crap info, should have taken a better look.. just needed a bit of help on this one.. anyone with any wiring the contacto and the switch info would be apreciated..
thanks
It probably is about 30 ish amps they pull a hell of a lot of juice especially if its the bulk brew kind with 2 urns built in,
I gotta go with time clock and contactor. only question would be, why does a coffee machine need to co on a timer??
The load can be quite high on these machines, separate boilers for water and steam, elements for the cup-warmer (maybe the reason for the timer).
A lot of commercial coffee machines are 3ph so the do pull a bit!
I understand why they want it on a timer but most machines require turning on( timer) and then various buttins pressing etc etc before they warm up so i dont see how the timer can help
Most timers are 13amp limit. So if the coffee machine is nuclear powered then you will need it to switch the contactor. Also having a separate timer makes it more user friendly for the customer. Can easy change switch times themselves.
Reply to coffee machine on a timer in the Talk Electrician area at ElectriciansForums.net
I am a landlord/owner of a flat. I am just about to spur off nearby sockets to provide the additional 24hr supply to new Dimplex Quantum storage...
All socket outlets up to and including 32A (which are commercial, not domestic) are required to be 30mA RCD protected. By the sounds of it you...
