Colour of sparks. | on ElectriciansForums
Discuss Colour of sparks. in the Talk Electrician area at ElectriciansForums.net
UK
With regard to lightswitches, some people claim to see a blue spark while for others it's green.
Why?!
When I read the thread title I was a bit worried about the content.
Were you thinking everything may not be black and white?
Re. O.P, ask a group of people to describe the same colour, whether sparks or not and you'll get varying answers.
If it's blue sparks, it's probably directly viewing the arc.
If it's green it's filtered thro' the plastic in the switch.
Yes if you hit a bit of galvanized with the mig you get a nice greenish glow, mind you that will be distorted through the shield.
Reply to Colour of sparks. in the Talk Electrician area at ElectriciansForums.net
Thank you! I didn't realise the wiring was QUITE that old… I'll replace it carefully.
That doesn't look a very big cable for the supply to a property. Could it be a 3 phase supply, in which case they'd be a bit more of a suitable...
