A
ash_s3
Hi all!
Im about to move into a house, it has a pretty new Worcester Bosch combi boiler installed but the control gear is pretty old and naff.
In the airing cupboard (where boiler is) is some kind of programmer which is fed via a SFS, i dont understand how to use it at all, all i know is it feeds the boiler via a 4G flex (all british gas branded stuff)
Its a mechanical one with the plastic tabs you push in when you want it on/off and its noisey as hell!
In the Kitchen there is a stat on the wall, its an old british gas own brand thing and part of it is missing! There is a 1.0mm T+E and 1.0mm Single core to it from the programmer.
i want to know if i need both controllers? what do they actually do?
id like to change them to digital ones, for both efficiency and looks, what do you recommend?
Thanks very much
Thanks very much
