Combi Boiler System Help! | Page 2 | on ElectriciansForums
Discuss Combi Boiler System Help! in the Australia area at ElectriciansForums.net
A
ash_s3
Hi all!
Im about to move into a house, it has a pretty new Worcester Bosch combi boiler installed but the control gear is pretty old and naff.
In the airing cupboard (where boiler is) is some kind of programmer which is fed via a SFS, i dont understand how to use it at all, all i know is it feeds the boiler via a 4G flex (all british gas branded stuff)
Its a mechanical one with the plastic tabs you push in when you want it on/off and its noisey as hell!
In the Kitchen there is a stat on the wall, its an old british gas own brand thing and part of it is missing! There is a 1.0mm T+E and 1.0mm Single core to it from the programmer.
i want to know if i need both controllers? what do they actually do?
id like to change them to digital ones, for both efficiency and looks, what do you recommend?
Thanks very much
cant find WPRS CM907
can find the CM907, is the WPRS version just wireless?
cheers
ash
EDIT: is it the CM927?
yep got number wrong wireless programmable stat(wprs not a code just short for)sorry,i thought about 80 quid but seems 100 more near the mark but they are smart units,and you can take it off the wall and carry it around on a stand even turn the heating on/off if the pubs close enough.cm927 then
Reply to Combi Boiler System Help! in the Australia area at ElectriciansForums.net
H
Combi boiler problem Hi this is my first post so please be gentle. I have a Worcester greenstar 28i junior combi fitted in my house, we were...
Happyharry
H
C
Small rental portfolio advice please. With the up and coming Renters Charter, its probably time to start thinking about increasing the efficiency...
Chris Taylor
C
