It's "normal".
A combi has a minmum power input, which for a water efficient shower may be too high for the flow rate. So you start the shower, and at first it calls for a lot of hot water. As the hot water gets to the shower, the thermostat reduces the hot water flow rate - and the boiler will reduce the gas flow accordingly.
But it sounds like the shower is reducing the hot water flow rate beyond the point where the boiler can reduce the gas flow rate any further. At this point, the water temperature will increase.
What happens next depends on a number of factors. The shower temperature may creep up a bit and the system settle in a state where it's using as much heat as the boiler can range down to. The boiler outlet temperature may creep up to the point where the boiler turns off - at which point the hot water temperature will drop failure quickly before the boiler fires again.
Or, as we think happened to mother the other day, the shower valve may throttle down the hot water to the point where the boiler turns off. It will then stay off until cooler water reaches the shower valve and the stat starts calling for more hot water. The boiler will fire up again, but by now the boiler and pipe to the shower will have cold water in them and the shower will go cold for a while while the boiler gets warmed up and the hot water comes through the pipe.
Just one of "quite a few" reasons why I "strongly dislike" combi boilers.
