combi theremostat | on ElectriciansForums
Discuss combi theremostat in the Australia area at ElectriciansForums.net
O
OlafIrolp
Ok the only reason im posting this is that im concerned... i have a thermostat and am convinced its not right... posted here before advice get someone to look at it... im certain it reads too low. the boiler Biasi Riva Compact HE MK 2 ... with drayton combi-stat. Two guys looked at it both said two wire. Part of me thinks this isnt right? I read and heard on this forum it may need natural also. Im sure its not accurate. I might be talk **** but if the boiler is coming off on it is doing no good to boiler switches etc. This is bugging me... sorry. Take now i have had heating on nice confortable temp... thermostat is lower.
you've had two people look at it and given there opinion why don't you think that is right? "it may need natural also" this is not necessarily true, depends on what type of stat, as to weather it needs a NEUTRAL or not.
Danny
can we clarify what the problem is? from the information posted, the stat is switching, therefore its working?
A stats job is to sense temp and call for heat yes or no?
I can't open the pdf but i would have thought the neutral shunt would have been omited as not all stats require it.
Might help if we knew what stat it was.
Edit
sorry if i knew ! think its only me that cant open file.
Reply to combi theremostat in the Australia area at ElectriciansForums.net
H
Combi boiler problem Hi this is my first post so please be gentle. I have a Worcester greenstar 28i junior combi fitted in my house, we were...
Happyharry
H
H
Worcester greenstar combi problem Hi this is my first post so please be gentle. I have a Worcester greenstar 28i junior combi fitted in my house...
Happyharry
H
