Combi with a 300 litre hot water tank
If the Landlord has other HMOs then they probably have the best idea of what suits that type of property.
It's his first so I think he has got confused advice. I have a couple of HMO's with a business partner. We use a 300 litre tank when we have 5 ensuites with showers. 2 run off electric leaving the 300 litres tank to deal with the remaining 3 showers. We use a system boiler instead of a combi.
Sure the combi heats the water as required and the stat doesn't need to call for it? Unless I am missing something
It will depend on the HW flow rate of the combi they've picked. A good one will run a shower fine, but maybe not 2 or 3. Could try restrictors on the showers to get over this I guess (?).
Won't make much difference, you just can't get the volume of water required because of the way instant hot water systems work.
Using a combi to run multiple showers is not going to work for the tenants, I would have thought.
Correct, you wouldn't spec a combi boiler for multiple showers that are likely to be used simultaneously. A pressurized system boiler with suitably sized hot water storage tank is going to be more cost effective and better for the job.
