Hi all,
Wondered if any of you have fitted one of these before that go directly above the shower ?
Are there any special precautions you need to follow other than the usual RCD protection e.t.c
Also the customer is adament they do not want the isolator switch fitted on the wall outside the bathroom, is it acceptable to put it in the loft within easy reach ??
Thanks in advance.
Thanks in advance.
