comercial board change | on ElectriciansForums
Discuss comercial board change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
bartkusal
London
Hello everyone and HNY.
I need clarification on this:
I been asked to change the fuse board in commercial premises, it is a sub main SP board in a basement area. The earthing cable/cpc to board is the armor of SWA cable, all circuits to the accessories has the cpc via metal conduit. I had a look at the job and the only tests I could do is Zs. The readings where in the range of 0.40-0.50 ohms, so it seems that I have fairly good Ze and R1+R2 (still to be confirmed when the isolation can take place)
I know that for new installs, you cannot have the armor or conduit as the only means of cpc, but it is only the board change and all wiring methods complied with the regs when they were installed.
So, the question is:
· Do I have to pull a new earting cable/cpc up to the board and,
· Do I have to pull in the cpc for all wiring in the final circuits
As you can understand it is a significant difference in work and cost involved and I don’t want to do it if I don’t have to. The client is a very tight as usual these days.
Thanks and best regards: Al
Since when.. If you have proved the results comply then crack on with the board change.. Simples
Thanks everyone for the replies, obviously i got that wrong, i dont remember where did that came from, i did reed that somewhere, probably that was a guide or recomendation and not the regs.
I need to look in regs book more offen then.
thanks again everyone
/QUOTE]
You could always do an R2 as it will give a better indication of the continuity of the containment system.
Reg 543.2.1
" a protective conductor may consist of .............
(vi) a metal covering, for example, the sheath, screen or armouring of a cable
(vii) a metal conduit,metallic cable management system...................."
Reply to comercial board change in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
Ok I’ll try this when I’m down
