Commando socket question | on ElectriciansForums
Discuss Commando socket question in the UK Electrical Forum area at ElectriciansForums.net
london
a client needs a 32a single phase commando installed so they can charge the forklift via a 7.2kw charger.
There is currently a redundant ring circuit adjacent, tested ring continuity and a is ok on the 32a RCBO.
Apart from sounding a bit piky can anyone see anything unsafe with the temporary arrangement?
You will have a fully loaded circuit for the charger on its own and presumably long periods, the legs of this redundant ring,they may have difference in the shared load
Maybe split the ring at that point and check the difference in the resistance of each leg,see if its going to stress any one side,
then consider blanking off any other outlets
That is Mable.
you remembered her name! That means a lot that does westie.
Has she settled in now.
No man. It's a long and very sad story, but I had to let her go to another owner, due to family pressures and my own impetuous actions when I got her as too-soon replacement for my previous dog. Shes doing just fine though, and probably forgot about me now. Thanks for asking anyway matey.
Reply to Commando socket question in the UK Electrical Forum area at ElectriciansForums.net
Better/Smart/intelligent/expensive generators require two earth spikes set ~10-15m apart. They check the resistance between spikes and will...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
:) The reason is cost, it only needs to allow fault disconnection and possibly extraneous bonding if TN-C-S (another thread...) 4C cable is...
Single Pole, Single Pole Switched Neutral, and Double Pole are all different things. Hager RCBO's are Single Pole. I was recommending Single Pole...
5K
  • Locked
  • Solved
Therein lies the problem. I see no merit in further circular debate, so will bow out of this discussion.
7K
nicebutdim
N
