Comments on this DIY job please? | on ElectriciansForums
Discuss Comments on this DIY job please? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening..
I am working on a large property at the moment putting in a new bathroom, kitchen etc. The owner has done a fair bit of DIY. One such job entails using a bit of 2 core flex (0.75mm) from a JB under the floorboards, then up the wall in trunking and across the loft where it reaches its position and drops through the ceiling into a pendant.
I have changed the JB to MF and will put a proper ceiling rose on the ceiling, however I can't quite figure out if there is anything wrong with the 2 core flex going up the wall. Basically it's not earthed, his argument is that it is normal for the cable coming from a ceiling rose to be 2 core, and he's right... this is just a very, very long ceiling pendant! ?? PS.. it's a plastic pendant. Plus many older properties don't have earthing to lights. I want to change it for twin and earth but I can't think of any reg that says this has to be done?
Cheers.
Evening..
Cheers.
All circuits need to employ a cpc whether use or not, some will more than likely disagree but I would never use flex as fixed wiring. Plus how would you test R1+R2 without a cpc?
So he is spending a sh!te load of money on a kitchen and a bathroom but arguing about the cable to the light, as mentioned above the cable should have a CPC as the chance of someone hammering a nail in to 9" of pendant cable is slim but the chances of it getting damaged in the run are a lot higher.
Just tell him you know better.
Evening..
... a bit of 2 core flex (0.75mm) from a JB under the floorboards, then up the wall in trunking and across the loft where it reaches its position and drops ... if there is anything wrong with the 2 core flex going up the wall. Basically it's not earthed, his argument is that it is normal for the cable coming from a ceiling rose ...
Hi HHD - Check out Reg 411.3.1.1 (last para)an exception is made for the pendant cable not needing a cpc. It's specifically for joining a lamp to a lighting point above it. Your case doesn't fit, in my humble opinion.
Reply to Comments on this DIY job please? in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
Promised a photo…. Remember, this was working…. And they managed to move in without hitting it…
