Comments on this DIY job please? | Page 2 | on ElectriciansForums
Discuss Comments on this DIY job please? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening..
I am working on a large property at the moment putting in a new bathroom, kitchen etc. The owner has done a fair bit of DIY. One such job entails using a bit of 2 core flex (0.75mm) from a JB under the floorboards, then up the wall in trunking and across the loft where it reaches its position and drops through the ceiling into a pendant.
I have changed the JB to MF and will put a proper ceiling rose on the ceiling, however I can't quite figure out if there is anything wrong with the 2 core flex going up the wall. Basically it's not earthed, his argument is that it is normal for the cable coming from a ceiling rose to be 2 core, and he's right... this is just a very, very long ceiling pendant! ?? PS.. it's a plastic pendant. Plus many older properties don't have earthing to lights. I want to change it for twin and earth but I can't think of any reg that says this has to be done?
Cheers.
So he is spending a sh!te load of money on a kitchen and a bathroom but arguing about the cable to the light, as mentioned above the cable should have a CPC as the chance of someone hammering a nail in to 9" of pendant cable is slim but the chances of it getting damaged in the run are a lot higher.
Just tell him you know better.
not very likely someone will nail cable in trunking.
That's a piece of mini trunking containing a shower cable that I installed a few years earlier. Painted over and a screw inserted!
[ElectriciansForums.net] Comments on this DIY job please?
HHD why did he run a supply from under the boards then up through to the loft when there would be a lighting feed in the loft already ? I must be missing something ?
Its a landing light so youre right theres lots of cables in the loft, but the switch is on the ground floor.
Reply to Comments on this DIY job please? in the UK Electrical Forum area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
Promised a photo…. Remember, this was working…. And they managed to move in without hitting it…
