Comments please | on ElectriciansForums
Discuss Comments please in the UK Electrical Forum area at ElectriciansForums.net
littlespark
Staff member
Supporter
Patron
Solutions
Scottish Borders
Went to price up a board change today from fuses to rcbo. Opened the outside meter box and saw this.
The fuseboard is on the end of the 16mm twin and (unconnected) earth about 1m through the wall.
[ElectriciansForums.net] Comments please
Tried at socket closest to board... 1.68ohms
Must be getting the earth from the water pipe.
I’d estimate 100 year old house, but occupant says the wiring was done early 80’s just before they bought the property.
yeh. I might be wrong with the 16mm, but it looks bigger than 10. Maybe the grey sheath is just thicker.???
Anyway. I think a call to Scottish power just to give me an isolator more than anything else.
just saw @radiohead reply ;)
Looks like the earth is not stranded ?
Another view....
Zoom in.... there’s a few strands to it.
I don’t know the internals the suppliers heads, but I think earth terminals come out the right hand side? Obviously blocked now.
should I contact SP, or ask the elderly woman occupant to do it?
That's an series 5 cutout. The lump on the right hand side is the customers earth terminal. Also the cover is missing from the bottom.
For some reason that is a split concentric cable with the neutral and earth commoned, Normaly it would be a straight concentric cable for a PME supply.
I would report it to SPEN as exposed terminals so they prioritise it, also ask them to clarify what type of earthing system it is.
Reply to Comments please in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
