commercial db numbering | on ElectriciansForums
Discuss commercial db numbering in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
mogga
How do you number a DB ?
is there a "universal" way to do it?
ie 1L1L2L3 2L1L2L3 ....... running down the db
or 1L1LL2L3 2 L1L2L3 1being left and 2 being on the right Odds down the left and evens down the right
what about odds on the left up from the main switch there appears to be no mention in the regs and every one seems to use a different system
Opps pressed wrong button what a numpty brains just not in gear today
i did it this way and labeled all sockets and switches to the circuit it was dedicated too
it had to be easy for the customer to understand using all the phase id is ok for us sparks but means nothing to the customer
so simple 1 to 36 each circuit had a coloured dot per phase so it can be easily identified
  • [ElectriciansForums.net] commercial db numbering
Reply to commercial db numbering in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
