sparks1653
I was thinking about fire systems for small buildings of flats, and what the best way to design them is. My main question is to do with the divide between communal areas e.g staircases, landings and each flat. whats the best way to approach this?...one big system throughout, or main system in communal areas and standard domestic smoke/heat alarms in each flat....as surely you wouldn't want one system running though out the entire building so if someone burns their toast in the morning they then need an entire main alarm reset..... all ideas and guidance appreciated.
