Commercial doorbell | on ElectriciansForums
Discuss Commercial doorbell in the UK Electrical Forum area at ElectriciansForums.net
A
aaelectric
Hi I'm using a 240 V fire alarm Electronic bell to be used as a door bell in a warehouse as it's a long run, 240v was the best option but on the connections to bell it has LL & NN im assuming this is in and out but if i want and time delay switch at front door which is 240v switching live how can i wire the bell. Can i have 1 switched feed in and thats it?
thanks
Since 1984 the is no such thing as a 240v fire alarm bell......love to know where you dug this up...secondly not sure i would be happy having an external door bell push button operating on 230v (ok could be ip rated, but not really practical)
If switching, distance is not a problem using say 12v, A localised psu could deal with this,
as its a long run that why we are using 240v. I have tried it on a plug and it works in terminal 2&4, sweet. the bell is inside and the switch is outside in a warehouse delivery. I am using a a Iprated time delay switch for button so it will ring for 5 seconds .
Reply to Commercial doorbell in the UK Electrical Forum area at ElectriciansForums.net
The light may have a permanent supply already inside it if you are lucky.
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
