commercial fire alarm | on ElectriciansForums
Discuss commercial fire alarm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
custodian
could anyone tell me the distance a detector has to be from a wall or fitting in a domestic turned commercial premises. I know it over 300mm for domestic but think it should be more
Thanks very much. I was at a job today where a so called niceic approved spark has mounted them as little as 360mm from the wall.
As said - 500mm minimum. There are also regulations regarding how close to lifts, light fittings, Air Con vents, shafts, ceiling obstructions.
500mm applies whether domestic or commercial - the detector cannot tell the difference!
Reply to commercial fire alarm in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I challenged a council on having the same system installed in an HMO. One consideration is if the flats/escape route were made to The Building...
Have you checked the RJ 45 type lead that connects the pcb to the power supply in behind is properly connected? What voltages do you get at the...
