Commercial kitchen containment | on ElectriciansForums
Discuss Commercial kitchen containment in the UK Electrical Forum area at ElectriciansForums.net
davesparks
Does anyone know what, if any, rules cover the type of containment which can be installed in a commercial kitchen?
I have always been under the impression that stainless steel conduit is required, but have never had anything to back this up.
I'm just working on a quote for a load of odd jobs which includes adding a few more sockets in a kitchen. And I most certainly haven't been given access to the other 3 quotes which have already been submitted, none of which include stainless conduit, they all are for standard galvanised (or galvaneised in the case of one quote!) so this has got me questioning my understanding.
think stainless is required in food prep. and cooking areas, but don't quote me on that. might be an adea to speak to your local environmental health officers.
I can vaguely recall something to do with the fixing of the containment, that normal saddles for the conduit were not allowed, they had to be a sort of stand off the wall type for cleaning reasons, I was not involved with that particular job though but another spark was querying a few bits with us.
As far as I was aware painted conduit was also allowed, that may have changed though.
http://www.bssa.org.uk/cms/File/Conf 03 SS for Hygienic Applications.pdf
About BSSA
Dont know if these help. Maybe worth popping an email off to the second link to see if they can point you in the right direction with regulations regards to the foods standard agency etc. personally I think stainless steel is the way forward in a commercial kitchen but it would be good to find a reg to back up your quote.
The rough surface gives a potential home to bacteria.
The possibility of corrosion wherever the galvanising is damaged.
I can think of plenty of rougher surfaces that would be just as close to food in many kitchens I have been in. And galv damage is usually repaired with galv paint. I would be extremely surprised if a health inspector snagged the specification of containment.
I know stainless steel is used for food contact areas but unless SS is in your spec for this job I think you mght be pricing yourself out of it without need.
Hospital saddles?
I'll try it on the laptop later, it may just not be working on the phone.
The next question that this logically brings to mind is what accessories should be used? Standard steel metalclad will have the potential for electrolytic corrosion, which everyone knows can be pretty rapid between steel and stainless steel in a damp environment.
As I said earlier I have most certainly not seen the other quotes, so there is no danger of me pricing myself out of this one.
Since the other people quoting haven't got a clue about how things are done in the entertainment industry I can well and truly spank their prices on the rest of the work, so overall if my quote for a few sockets in the kitchen is bit higher than them I'll still be leaps and bounds ahead of them.
Reply to Commercial kitchen containment in the UK Electrical Forum area at ElectriciansForums.net
That's really helpful. Thank you so much, I will take a look.
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
